MrMarty51
- Oct 25, 2012
- Eastern Montana
- Martin
- K20
No, 79 is a Race Track Pattern 32 spline. Round Pattern didn't start till like late 85 or 86.
What you have there is also a Race Track pattern, but in a 27 spline.
AAAHHHHhhhh, so that is why that kit comes with the trans/205 mount and a bunch of other stuff including, the input shaft for the 205.
And so, if there is such a thing as, a 205 coupled to a 400 trans. of about 85 or older, I then could have all it`d take to hook them together, trans to 205/mount adapter with the 205 input shaft. anything else ???
I`m getting bearings/seals installed into housings today.
Danged rear output shaft has one of the pins for the thrust washer broke off flush with the shaft and the other pin was`nt even in there. fugggg, now I`ll be drilling an 1/8th inch hole into the shaft and then making a set of pins. should work though.
