Propane injection removal
4WDKC
Southern Florida
Kacy
What would be involved in completing this?
SDJunkMan
Black Hills of South Dakota
Jeff
Never ran propane, but used to have CNG (compressed natural gas) on several trucks. They either ran on CNG or gas, it was not a combination of the two, so I am not sur if that is how your propan system works.
If I recall, besides the tank, regulator, and plumbing, there was an adapter that mounted between the carb or throttle body, as well as an electrical module. I don't recall having to change anything after removing thase parts.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Righty tighty/lefty loosy.
Close the valve at the tank.
Remove the lines.
Remove the engine coolant lines from the regulator.
Safety cutoff valve and carb.
Tank.
If the system was installed by a good mechanic the advance spring in the dizzy will be too soft for gasoline.
You can drain the tank into barbecue cylinders. Need an adapter and a deep freeze and sunshine. You want the tank in the sun as hot as can be,
and the barbecue tank in a freezer. You can use the fuel line already on the tank.
4WDKC
Southern Florida
Kacy
Remove the lines.
Tank.
Its on a tbi truck.. anything extra?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Remove the lines.
Tank.
Don’t forget send it to me lol then I only need 1 more set up to run dual mixers. Lol
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Oh so it's a closed loop.
Well the only thing to be sure of is to close the feed line from the tank, and go nuts.
I don't have any experience with closed loop systems, but I understand they totally rock once dialed in. And of course, in order to get any performance
out of pane you need... COMPRESSION!
4WDKC
Southern Florida
Kacy
Its on a 350 tbi motor in a 3/4 -1 on srw, so no compression.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
I was going to say, when you get everything off put in box and ship to the shiftpro...
Can run dual mixers (or regulators as some call them) behind one carb (Impco 425) and more power will be realized.
But for truly more jam need two mixers and two carbs!
A stock 454 with one 425 and 1 mixer will do alright. Torque and throttle response is good but the power runs away after 3000rpm.
Add two mixers into the 425 Impco and even with only 425 cfms it's amazing how it helps. These systems tend to run out of fuel before air, so
richen it up and away we go!
And to reiterate, run two Imcos and 2 mixers for ultimate smile factor!
Some guys claim to realize better fuel economy with the double double setup...? probably because everything is so much efficient as far as
making power. You all know that making more power means better efficiency which = economy (to a point, and also depends if you are actually using
all the extra jam on tap)
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Yeah I figured as much. If this mill had decent compression (min 10.1 but more is better!) it would be very impressive and probably not going back
to gasoline.
Unless of course there are other reasons for pulling the system off (like can't find auto propane for sale)
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
There might be an add on computer too. The modern closed loop systems have a second computer.
4WDKC
Southern Florida
Kacy
to gasoline.
Thats one reason, another is I have a 454 that would be perfect for this truck, then this 350 could go in my 4x4 along with a for sale sign.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I’m good with straight propane. There is an automobile filling station 5 miles from me.
DamnTexan77
