- Jul 3, 2012
- Right where I am
- Bagoomba
- 81-C20 Silverado Camper Special-TH400-4.10s
- Carb'ed Vortec 350
Awesome!
I like the idea. Obviously the wheel you're using is a 5 lug and your burb is a 6 lug. Also, you'll want to check that the old rim will fit over the hub of the burb and I do believe you have to use a 16" or larger rim due to the size of the calipers. Just some things to think about.
Yeah, going with Stock steelies with rings and caps from a 98 GMC K1500. gonna paint the wheels black.
I couldn't find a pic of that setup on the interweb thingy.
I look forward to seeing the look. No many people do it so it's good to see different
I think the standard wheel size for the GMT800 Burbs/hoes and trucks was 16" so you will be fine there if you go with a 16" steelie. Keep in mind that the Police Tahoes used a 17" steelie with a cap too if you like that look too.
Good choice, George. Those big brake kits are fine but IMO they are overpriced and you can get just as much stopping power out of OEM spec high quality parts
