- Dec 7, 2010
- Southeast PA
- Paw Paw
- Chevrolet Tahoe LT
- 5.3, 4WD
sorry to be butting in here, just gonna see if anyone has any input on this.. I think the water pump is oem... I think the water pump is cracked, it seems to be leaking from the side of the lower hose tube, does that sound right? do these things just wear out and start to drip? its pretty rusty
not sure if you can see the drip or not, its kinda a bad pic, its right above the hose (shot from under the truck)
There is a weep hole under the bottom of the pump if the inner seal goes bad. Check your hose clamps, snug them
up.
