Can I rebuild it?
Iowan
Loud and Proud American!
Iowa
Calvin
K1500
350 crate
Hello, I found an engine for sale and its a 350, the story goes the guys daughter ran it without oil completely dry and obviously its dead seized but its also only 40 bucks so can I rebuild it? If not I'll have something to take apart and put back together. Thanks guys!
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Gotta get it apart to see the carnage. You can bet on a bunch of machine work for sure.
Iowan
Iowa
Calvin
K1500
350 crate
Okay I figured. Thanks man
MrMarty51
Eastern Montana
Martin
It is well worth the 40 bucks, even as a core.
Depending on where the piston size now is, might make a good engine by buying a complete engine kit, crank and all. Build it to Your specs.
74 Shortbed
I'd offer him $25, heads ought to worth that much???
Yes, it can rebuilt. For $40. I'd jump all over it if it's really a 350 and it's just seized and not a rod through the block. So find that out.
Maybe, seen quite a few that seized up and destroyed a main saddle, it's a gamble don't know until you tear it down.
I could see how that's possible. I've never seen it though. Good reason to always check the line bore.
74 Shortbed
Yep, depends on how long it ran when the crank grabbed a bearing, it can be nasty..
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I generally use the rule of thumb if the main saddle is blue it's junk.
Georgeb
Wisconsin
George
K10 Burb Z71
I know @Iowan is a young man just getting started in the world of trucks. I would like to provide a little lesson I learned when I was younger. When I was starting out I had all sorts of ideas that appealed to me. I wanted to put a V8 in place of the I6 in my Dart. With the help of some great guys that pointed me towards the parts I needed (no internet back then), I was really close to making the swap. I had already swapped the rear axle and converted to a 4spd manual. I had an almost complete 318 minus a carb and dizzy. Someone had told me the motor may need to be rebuilt so I took it apart and started thinking about a rebuild. Long story short, I didn't have the funds to do a rebuild at the time and after a few bad deals with other parts where my youth and inexperience was used against me I didn't even have the cash to get back to where I was before.
The moral of the story and what I should have done was be sure to spend my money wiser and be sure I was getting somthing that was worth what it cost and also useful for the project.
If I were @Iowan I would keep my money and look for a 350 you can hear run and that has good compression. Buy it and drop it in. Use your $25 or $40 bucks towards hoses and other incidentals that go along with an engine swap.
Georgeb
Wisconsin
George
K10 Burb Z71
Besides, you can always pull and rebuild it later.
PapaBear8486
