99 taco 4x4
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Some befores...
And after...
I thought about replacing front bumper, but figured if I go tube style later, why...
Still got my drive belts to put in...
Do you still have Project F Smog???
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
Thanks. They hold value so much most are un buyable unless your willing to overspend, or I lucked out and got one that needs maintenance, but was cheaper initial purchase price...
I have an FJ Cruiser that's valued at like 80% of what I paid for it new lol. Toyota values are silly.
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Yes
My brothers wife had a black one... It was more manuverable than I would of thought, but then they traded it for back seats of sequoia, then got a sienna van for sliding doors on both sides due to my neices... Values are nuts
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Got the drivebelts in today....
Old...
New....
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
So this is what I still need to do and some things I want to do as $$ permits:
1) Fix Seats, drivers bottom is worn to foam/ passenger side soiled.
2)touchscreen cd/ mp3/etc.
3) fix antenna, its ripped off...
4) wheels, maybe 17s vs 20s oem
5) 3"revtekcoil spacer type lift
6) mts
7)susp kit, for tie rods, ball joints etc
8) ps rack per toyota but after mini me it may just need banjo washers
9)align,
10) lcengineering header,
11) 2.7 supercharger,
12) pedal rubber missing
Crispy
Carbon County, Pennsyltucky
Suburban V1500
Nice score there. Those old Yotas really command a high price but they are solid trucks. The OEM 20s you had in earlier posts look awesome but not enough tire IMO and will be more $ to replace tires when the time comes but you seem like me in the sense you might not have it long enough to replace tires lol. Enjoy the build!
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Thanks. I have been waiting for tacoma for a long time... I like to think the only thing I'd possibly want at this point is a four door which were like double (for salvage title) to triple the price (clean)/but lifes weird....
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Scratch number one off the list....
I had been searching and recyclers didnt have grey, and wanted $450 for a set of 03 seats from a prerunner double cab.
But then I saw these.... I got fingers crossed with enough elbow grease I can get the soiled / stains out....
So I have two buckets...think it was bench stock... Have center console... So I was focused on the passenger seat-with the idea to take the foam seat bottom and back and swap them to my ragged driver chair- but he wouldnt break up the set.... So I bought em for $160.... Maybe I can try both out...
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
This was how I bought her....
Once the covers removed... Passenger side is solid, but stained.....
So hopefully I can put the good foam in the bed on the beat up seats in the cab, and clean the other one just to see, if anything it will help with resale value...
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
I mean resale value of the seat I end up not using ....not the car:smoke2:
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Moved it inside....
Ledt driver to be replaced...
Middle purchased pass for cushion swap....
Right 60/40 thrown in may try itx but has slight leather rips up front
Couple screws to remove plastic covers...
4x10mm or 12mm to remove seat bottom.....
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
So we get into removing the back fabric, clipped together on bottom
Got the foam off now... Making a mess
Gotta get back frame off...
Four 12mm
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Bolts on other side to get back off....
Back off...
Now to the newer back pass to swap to driver frame...
Opening up the innards....
All for this....
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Started with this...
Swapped cushions over...
Now two options for driver...I it looks like it is leaning on the 60/40 because it sits on transmission tunnel with short inner leg...
Just need a good cleaning...
