wtb full set of 5lug rallys or mags...no tires needed
Marine Corps Moderator
I've got a compressor, and good hoses that I won't be needing. What do you mean a breather for the top of the motor? Crank case air breather?
I have to check on a Radiator
1low4x4
Nick
The air filter breather.
1low4x4
Nick
Ok so wheels, trans linkage stuff, headers, ac compressor, (the smaller one, not the long style) possibly a radiator and breather for top of carb...
Got one of those rubber things the hood sits on in the core support? One on each side...they are adjustable. ..to control how far the hood comes down. Need one kind sir.
Are these them, or do you need the kind that have the screw?
Checked for a Radiator, I have the one for a 73-80 it's shorter. Probably the one you have already.
The air cleaner I have is a 14" cheap chrome one, and it has some surface rust. You can get one at any auto parts store for like 20-30 bucks. If you want it, you can have it, it's up to you.
Do you need the hoses for the A/C?
1low4x4
Nick
If the hoses are in good shape I do. I have hoses but not sure how old.
Those.are the hood things I need.
Your pile is getting bigger and bigger. LOL
1low4x4
Nick
Lol. I also need one of those battery hold down things. Its like a little wedge that clamps th battery to the tray. And the bolt.
Also...LH and RH tail lenses? Mine are replacements and don't have the aluminum trim around them.
And do those headers have the bolt on collectors to use? I need them or ill have to buy some
I'll have to go see if I have a good set of tail light lenses.
Battery hold down clamp, I've got.
Yes the headers have the collectors.
OK.....List of goodies for Nick:
Rally wheels, with OK tires, Beauty Rings, and Center Caps
Long tube Headers, with collectors
Shifter parts
Hood adjusters
Nice Tail light Lenses, with Chrome trim
A/C compressor, NO Hoses
Battery hold down clamp, with bolt
Am I forgetting anything?
Are you going to come up hwy96?
I can meet you some were, so you don't have such a long drive.
Did you want the Chrome air cleaner?
1low4x4
Nick
Shifter parts
Hood adjusters
That list sounds good. The ac compressor is the pancake style right? Not the long big one.
You know hkw on the core support where the headlights go, they use a few of th adjustable rods that clip into the core and aim the headlights. And then one corner has the spring.
I need a few of those springs.
Name a place between carthage and lumberton somewhere! Doesn't matter to me
I'll have to look for the springs.
1low4x4
Nick
Awesome. How about a spare gas gauge for the cluster?
Head light tension springs:
I doubt I have a gas gauge, I don't run stock gauges, so I probably threw them away, I'll look
Brianall
