WTB: Antenna & Antenna Base/Mount 90 Burb
donmateo
WI
Mine snapped when I was taking it off before a wash. Need the mount/base and the actual antenna. Not sure if there's a difference, but it's a 90 Burb front clip. TYIA! :cheers:
donmateo
WI
Bump!
donmateo
WI
Bump, I'd like my radio back lol
Georgeb
Wisconsin
George
K10 Burb Z71
Where have you looked for one? I have one on Clifford but the cable is bad. Used to be able to order them right from NAPA. I may know of one but it will be a while before I can look.
donmateo
WI
Been looking all over, but I jus need the base for the bolt, if I can use my wire that's on there I really just need the base for the bolt as mine snapped, if that makes sense.
Georgeb
Wisconsin
George
K10 Burb Z71
Pics?
donmateo
WI
I'll try to get some later, but the bolt is literally snapped inside the base thread and half in the antenna thread.
donmateo
WI
Here is a pic of the base w/out the rubber cover on it. As you can see, the bolt sheared off inside it. Damn thing...
Georgeb
Wisconsin
George
K10 Burb Z71
Have you ever had it off before? If it was mine I would attenpt to drill it and pull it with an easy out.....
A few days soaking with penetrating oil will help.
Sorry, I dont have one of those style bases.
donmateo
WI
No, I haven't. I'm actually away at school and all my tools are at home. I will be back home soon and will try. Thanks for the tip! :cheers:
Georgeb
Wisconsin
George
K10 Burb Z71
Sure. I would suggest you mask the area around it with some tape so you can easily clean up the chips without scratching the paint.
Those antenna bases can be found on other GM cars too, I know all of my Celebrities have had them. The covers can be found in black or polished stainless.
donmateo
WI
Good to know, thanks for the info! :cheers:
Looks different in design from stock, should fit and look fine though.
504SquareBody
