Wiring kits
BigPoser
Bakersfield, CA
Brandon
Cheyenne Super 10
Looking to possibly re-wire my 73 and have seen a few kits from American Autowire as well as Painless Performance. Thinking of something like this, http://www.americanautowire.com/shop/power-plus-20-kit, but not sure just which one would be the best fit as they have quite a big range. Anyone have any thoughts?
Thanks in advance.
Brandon
Joshua8336
Dirty South AL
Joshua
speedway motos has a 12 circuit wire harness, basically a painless harness but in a different box for like 120. i'll see if i can get you a part number
EDIT:part # 91064017
highdesertrange
kalifornia
mike
k30
I don't know about anything but those other companies. I have only used Painless and found them to be top notch. btw do you still have a breaker point distributor? if you do you must have the correct resistance wire in the kit for the coil or you must use an external resistor. highdesertranger
Lugnut
Northwest Georgia
Jason
'79) 350/ granny 4-speed, '86) 350/A833 3-speed with overdrive
I just got through installing an American Autowire wiring harness in my 1956 chevy I've been restoring. I was very pleased with it. All the wires were factory colors with the correct ends and plugs. Made for a real neat and easy job.
BigPoser
Bakersfield, CA
Brandon
Cheyenne Super 10
Yeah I'm kind of leaning toward American Autowire as well. Summit has a great kit for $70 less than American sells it on their site. Should do everything I need.
BigPapa
