wipers
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
when i turn my wipers off they dont go to the stop position. what is the problem? 87 r10
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
About the only advice I have on this is pull the plug off the motor and check for corrosion on any of the contacts, scrape if needed. Otherwise I would replace the motor, I dont think it's very expensive IIRC.
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
i replaced the motor .same thing. could it be the switch
dirtroadoutlaw
Florence, MS
k5
The smaller of the two plugs on the motor is the plug for that. It should be getting power when the switch is on the "off" position!
Sent from my SCH-I500 using Tapatalk 2
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
Is it possible that you removed the arms and did not get them back in the right location? If so, loosen them while off and drop them down to where they should be, then retighten.
Where do they "park" (that's the term for final position)?
Do they always park in the same spot?
By any chance do they park at the top of the stroke (i.e. all the way to the left)?
If they consistently stop in one position there is an issue with the mechanical alignment.
1. 180 degrees out:
The motor output shaft has 2 flat spots. Release the linkage from the motor shaft. Turn the wipers on and then off. With the motor shaft disco'd from the linkage, manually set the wipers to the correct park position. Then, with the motor stopped in park and the arms in a reasonable park position, re-attach the motor to the linkage.
2. Some arbitraryly wrong position:
The arms are driven by splined shafts. It may be that someone set the arms on the shafts incorrectly. Pull the arms off and using trial and error, determine a good park index between the internal arm splines and the external shaft splines.
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
when i turn them off thats where they stop
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
Oh! I totally misread that question. Your problem is that yours don't park. They just stop where they happen to been when you turn them off? Hmmm....haven't seen that before. I would think it would have to be something with the motor though. :shrug:
crazy4offroad
K-10
350/SM465/NP205
I dont think there's any special module that controls it, just the motor and the switch. I would replace the switch now, it would be best to find someone with a working switch you could just swap in and see if it fixes it.
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
Curt, is the circuitry to park the wipers in the switch or the motor?
crazy4offroad
K-10
350/SM465/NP205
I'm assuming switch, since he already replace the motor and it still does it.
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
What happens if you spray the washer? What does it do?
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
ill check it out and let you know
76stepsidechevy
CT
Justin
Theres a ground wiper tab inside the motor. The tab wears out or gets out of adjustment over the years and then the wipers just stop wherever they are when you shut off the switch. If you pop the cover off the motor the tab can be bent in so it makes contact again and you'll have wipers that park at the bottom of the windshield again.
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
But he said it's a new wiper motor.
