Wiper/ turn signal switch
Layne02
Ga
Jeff
R1500
So my high beams are stuck on permanently , nothing happens when I pull lever back to put on low beams. The turn signals work, wipers do not. I assume all that is same switch which seems very hard to get to. Am I right? If so, what all has to come off? Seems like its way down in column.
gpmorgan
Tupelo Ms.
greg
Your high/low beam switch is mounted on the collum under the dash. You may have a bad wiper motor possibly.
Yeah, I’d see if the wiper motor is getting juice, as well.
Layne02
Ga
Jeff
R1500
As far as the high /low beam, when I pull the lever back, there is no click. Should there a be a " click"?
Is the lever seated all the way in the switch?
gpmorgan
Tupelo Ms.
greg
Sounds like signs of bad switch or switch is out of adjustment.
Layne02
Ga
Jeff
R1500
Yes as far as I can tell it is in all the way. So if its a bad switch, is that a pain to get to?
Well, the reason I ask is I’ve seen them not all the way in but they look and feel like they are, and the dimmer won’t click. In the same situation, however, the turn signals will engage. I’d doublecheck that before proceeding because that’s what it sounds like to me. Otherwise, I’ve never had the pleasure of replacing the switch so I can’t speak to it.
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
The dimmer switch is exposed on the driver's side of the steering column. AC Delco # D832. Under $20.
Looks like this inside the column:
Expose the switch, toggle the stalk and observe whether the actuating rod is moving. The switch position is adjustable by loosening the screw and nut. If the rod moves a sufficient amount, but the switch doesn't click, you could try to move the switch closer to the end of the rod.
But, if you do that, be careful not to disturb the position of the ignition switch. They share the same securing fasteners:
Layne02
Ga
Jeff
R1500
OK, so I got the dimmer exposed so I could see it . when I pull lever , the dimmer is moving , but, no change in lights. So , could dimmer move but still be bad ,contact inside not contacting , or would it point to wiring problem?
Oh, I think lever stalk is pushed in all the way, I tried pushing and twisting it in several times, cant get it to go any further.
ajd89
Central Michigan
andrew
I couldnt get my highbeams to turn off eithier. Ended up the switch was melted and burned together swaped out that part and worked fine afterthat. Kind of a pain to get to but it can be done.
When the stalk is toggled between HI/LO beams the actuating arm moves toward the switch about 1/4". As suggested above - if the switch is working properly - it should emit an audible click. The click sound is pretty loud - usually loud enough that it can be heard under all driving conditions.
Check the nut and screw that secure the mounting plate to the column. If they are tight, that would indicate that the switch hasn't moved from its original location - so re-adjusting it probably won't help.
If there is no click (and the switch hasn't shifted from it's proper position), you can be fairly confident that it isn't a wiring problem - the switch is bad.
You have already done most of the steps involved in changing a headlight dimmer switch. Get a new one from almost any auto parts store for about $20. Then:
1. Disconnect the harness from the switch
2. Mark the positions of both the dimmer and ignition switches in relation to the securing fasteners with a Sharpie. Also note how the two mounting brackets are stacked - I think the dimmer switch bracket goes over the ignition switch bracket. Remove the two mounting fasteners:
3. Put the new switch in place and bring the nut/screw up - but only fingertight
4. Align the switches using the locating marks you made earlier
5. Tighten the fasteners, reconnect harness to switch and test both switches (i.e. the starter operates and the beams flash up/down)
6. If both switches seem to be properly located, close up - you're done.
If you find it difficult to do this procedure in the tight space above the column. Remove the nut securing the column support bracket and lower the column until the steering wheel rests on the front seat:
RustyPile
Left on own accord
Elkhart, TX
Nick
1983 GMC
350 SBC
Caution!! Before proceeding with the above highlighted step, disconnect the little shift indicator cable where it attaches to the shift lever collar.. Not doing so will damage the shift indicator..
