Wiper motor wiring help
1973c10
Don
Can anyone tell me what wire go's where
Thanks much
74propu
florida
austin
c10s/b c10 s/b c10l/b
5.3 / ?/454 tbi
73 give me till saterday and I will get in my 74 and tell you what wires go where on the wiper motor and the switch.
1973c10
Don
That would be awesome thank you
74propu
florida
austin
5.3 / ?/454 tbi
Thanks much
wire 2 is 12v+ wire 1 is low speed - wire 3 is high speed - wire 2 also go's to washer pump . on the switch there is 3 connections starting with the one next to the steering column it is los speed the center is high speed and the one next to the door is the wash pump ground the switch is the ground. hope this helps.
1973c10
Don
You rock thank you so much
I will let you know how it turns out
1973c10
Don
Do I have this right ??
74propu
florida
austin
5.3 / ?/454 tbi
that is right or that is how my wiper is wired
1973c10
Don
is there a ground wire running to the switch body
or dose it just ground to the dash ?
I hooked it up like shown in picture and nothing LOL
Georgeb
Wisconsin
George
K10 Burb Z71
There should be a ground strap for the wiper motor. If you have power on all three leads like you should try grounding the case of the motor.
1973c10
Don
I got it fixed thanks for all the help
it was a grading issue when I painted the fire wall
and put everything back together I should have
removed the paint from where the case of the motor grounds LOL
