Window/Door Weatherstripping
GunMan9
Yorktown
Brandon
I have the vent window rubber already. Where do I pick up the door seal? Is that the piece between the window and vent window. Can you get it in chrome?
guitarfreak235
Spartanburg S.C.
Andrew
k10 c20
No it's between the door and the cab, you are probably fine with the one you have
Rock auto lists the Fairchild window strips (inner and outer - both sides) for 40 and the channel runs for 15 apiece = $70. So depending on S&H charges, that's probably as low as you'll find.
GunMan9
Yorktown
Brandon
Ok thanks. I just picked the ones up from rock auto came out to 75.95 shipped
