Will These Wheels Work?
moorevisual
Atlanta
I have a set of stock 15" wheels from my 1980 Caprice laying around, same bolt pattern 5x5. Would I have any issue using these on my truck? Mostly curious about the truck's front suspension, it's lowered with drop spindles and springs.
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Check the backspacing of the rims compared to what you have on now.
If the backspacing is smaller, then it will push the wheel out and more likely contact the outer fenders.
If the backspacing is considerably larger, then it will pull the wheel further in and may contact the frame and/or inner fenders.
