Where to get pieces to put my 76 Ac back
NCTyphoonKid
Trinity,NC
Korey
Silverado R10
Where do I get all the hoses, compressor, condenser and the other pieces associated with the factory Ac system someone removed pretty much my whole factory Ac system and I want to put air back in it
yevgenievich
Viktor
sad
very sad
less sad
Almost everything should be available through parts stores. Dryer, hoses, condenser, evap core. I have a used evap core from 80's it fits and you need it.
chevyk10
WV
Daniel
1984 chevy
k-10
358 Dart block with aluminum heads 430hp/450ft-lb torque
As long as you have the cover that bolts to the firewall and everything under the dash. You can get about everything else.
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
I didnt want to take the chance when installing my ac unit. I sourced everything through my local auto parts store. The bracket for the ac compressor was the only item that I had to source from a c10 parts truck locally. I also bought the frozen ac compressor from a local parts yard for $10...and used it as a core since the auto parts store was charging me $50 core fee without the exchange.
eatfood
