Where can I buy the warning light lens like fasten seat belt choke lens and 4x4 lights lens
wildone454
wv
cody
Looking for stores to buy the lens that has the warning letter on them for the clusters and what are the correct ones that goes into a 1983 cluster I know there is a low coolant one as well is that one on a 83?
dsteelejr
Hudson, WY
I have a ‘73, ‘80, ‘88, and at one time had an ‘84. I’ve never seen a square with a low coolant warning light or a provision for a coolant level sensors. They’re called tell tale lights and generally they are brake, fasten seatbelt, four wheel drive, and choke. Later, on TBI engines, choke was replaced with service engine soon and I’m not 100% sure since I never messed with the 6.2L diesel but I believe they had a water in fuel light.
I haven’t seen the lenses for sale on any retail sites. Try eBay or a junk yard. You may have buy a used cluster to get them.
wildone454
wv
cody
wildone454
wv
cody
dsteelejr
Hudson, WY
I know I haven’t seen it all and that’s the first low coolant one I’ve ever seen. Any idea what year or application it’s for?
wildone454
wv
cody
no sir I’m hoping someone on here can chime in the reason I posted the pics was to see if you know about the brake one which one are in yours
wildone454
wv
cody
New boyz square body rescue had them to buy so I found the place just need to find the correct application I went ahead and order the set without low coolant but still would like to know more input on them if anyone knows
bajadiver
