Where are the 8 bolts needed to loosen fuel tank
86squarebody
apison tn
scott
I have a 1986 Chevy Silverado. One of the fuel lines have burst. I was trying to drop the tank, but can't find which bolts I need to undo. I am a newbie at this so please be descriptive.
MadOgre
NA
NA
NA
NA
NA
They are on the inside of the frame rail at the locations where the hanger brackets are mounted to the frame.
86squarebody
apison tn
scott
So the holes in the frame where you can see the nut. This is the nut I want to take off right?
MadOgre
NA
NA
NA
NA
NA
No the bolt and Nut is for the strap. You need to drop the whole tank first.
MadOgre
NA
NA
NA
NA
NA
MadOgre
NA
NA
NA
NA
NA
You must remove the 4 bolts that attach the brackets to the frame. Be sure to support the tank some how and remove the fuel lines and wires as you ever so carefully lower the tank. Also don't forget to remove the fill hoses :)
Each bracket has 4 bolts. so 16 bolts in total
86squarebody
apison tn
scott
Thanks all of you guys for the replies. Also thanks MadOgre for the pictures. They helped greatly
chengny
Here is the parts list and assembly drawing - it might help:
winterhawk
