Wheel stud problems
swampdonkey
Ohio
Ben
K10 Scottsdale
ok i would really appreciate some help. i am pretty new to working on vehicles and i have a small problem. i need longer wheel studs for my 77 k10. every site i look at gives me 2 different knurl diameter and underhead length sizes. the knurl diameter and the underhead length are chinese to me. what are these 2 measurements? and how can i tell what mine are?
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
Wheel studs have flaired out parallel ribs on them where they pass through a wheel hub, these are called knurls. They are typically 1/32" or so larger diameter than the hole they go in, so the stud doesn't spin when you tighten a lug nut. The length of the knurl under the head is the underhead measurement. This should be approximately the same as the thickness of the wheel flange the knurl goes through. Rear wheel flanges arent as thick as the front. Rear it just goes through the axle shaft, where on the front it goes through the hub and the rotor. Hope this helps!
swampdonkey
Ohio
Ben
K10 Scottsdale
thanks for clearing that up. any idea how i would go about finding those measurements to be able to order the right studs?
Get your hands on a micrometer and measure an old stud and/or the hole.
Welcome aboard. :wave:
You may get a parts counter guy to go through a wheel stud catalog to get the specs of a stock replacement stud.
Whereabouts in Ohio are you?
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
Find a parts guy that knows how to look them up in a DORMAN catalog. Once you find your stock ones in there its easy to find some that are a lil longer with the same knurl.
swampdonkey
Ohio
Ben
K10 Scottsdale
thanks everyone!!
I got a good source that says to use these:
Dorman Part #'s:
Front: 610-179
Rear: 610-186
Dorman Part #'s:
Front: 610-179
Rear: 610-186
Is that for stock length, or a little longer?
jon wandvik
