What's this wire?
Jason in KC
Olathe, KS
Jason
Obviously the larger green wire goes to the compressor, but what's this one for? I'm trying to convert my temp gauge back to stock from one of those cheesy 3-gauge clusters that hang under the dash - eliminating the oil line (red). The other green wire (yellow) goes to a temp sensor in the side of the block. I believe there are actually TWO temp sensors? But the wire in question isn't long enough to reach the one on the top/front of the intake. 1979, if that matters. Help, please?
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Should have known, but had to go look.
1980 Suburban - that is for the ac idle up solenoid.
Pics!
Jason in KC
Olathe, KS
Jason
Sweet, so I can eliminate that one from the mystery; thank you!
But what else could I be missing for the gauge to be inoperable? I bought new gauges, so that ain't it. Do I only need the one temp sender? I'm wondering if that's faulty, but it was replaced not too long ago.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Mine only has 1 temp sensor, but, if you got new bad gauges ...
One other random thought - notice that ground wire in my loom running over to the thermostat ? I do not see that on yours.
Jason in KC
Olathe, KS
Jason
Ooh, that may be it. I definitely do not have that ground wire hooked up to anything in that area; I'll look at that tonight. Thanks again Goldie!
jw23655
