What will bolt directly in
bigbug6900
US
I have a 1977 stepside I was looking for a ford 9inch that will bolt directly in with minimal problems any and all help is needed
Sent from my Z970 using Tapatalk
J Knight
Baytown TX
82 Chevy
350ci
Their are no direct bolt in 9in rear ends. Your factory 10 or 12 bolt is 64in wide from wheel mount surface to wheel mount surface. You will need to find one close to that wide unless you are going to tub or mini tub the truck. You will have to remove all the mounting brackets off of the 9in and instal new spring perches and reuse your old shock mounts. Ford truck 9in have 5.5in bolt circle and even some later models have a 4.5in bolt circle. Most car 9in rear ends have a 4.5in bolt circle but the Ford Thunderbird and the Lincoln Continental from the 70's have a 5in bolt circle.
The only way you might be able to get a direct bolt in would probably be Currie Enterprises in CA, they can build a 9in to your specs. They might have the specs on a c10 but I dont know for sure.
The best way to do this is to find a rear end, take it to a rear end performance shop, have them build it to your specs with new gears, carrier, axles, and brakes. Then when you get ut home you set the rear in place and weld in your mounting hardware, run your brake lines, and measure for drive shaft. It will he pricey but it will be right.
The cheap way to do it is to search till you lose you mind for close to what you want and just make it fit.
I picked up a free 9 inch a couple weeks ago, knowing nothing about it. While digging for info, I realized most (if not all) of the housings were narrower or wider than what these trucks of ours have.
lessersivad
Morenci, MI
Russ
1977, 1979, 1982, (2)1985 1985
C10, K20, K10, K5, K2500
This is my 1st post but I hope it helps.
According to this;
http://www.crankshaftcoalition.com/wiki/Wheelbase,_track_width,_and_differential_measurements#Ford
It is as I suspected, the early to mid 70's full size Ford (LTD) comes real close to the right width @ 63", which would be a mere 1/2" per side. It will also have the 5x5" wheel bolt pattern.
This is a possible option for my '77 C10 as the gears are rather steep but I may go in a different direction with the truck.
Granted mounting points will have to be done as the Fords came with coil spring suspension as opposed to leaf springs.
Again, I hope this helps.
