What to do with gas tank vent when all emissions components are deleted?
I am replacing the gas tank on my 1980. The.. previous owner was my grandfather. There are three nipples coming off the gas tank sending unit thingy, and one of them I presume is a vent for the fuel vapor for the canister. That stuff is since been long gone on the truck. He had it plugged, but Im guessing some of my fuel issues was having a gas tank that couldn't vent... on top of the rust and bad gas gauge unit haha!
What should I do to it?
ali_c20
Austria
Alexander
C20, K5
You could leave it plugged and buy a vented gas cap.
Dan Miller
K15SG
Indiana
Daniel
K15
My tank has a ventcap like on an axle vent tube . It has only one vent line coming out of it tho, but it will vent. I will take a pic when I get home
For the time being a drilled a tiny hole in the gas cap(just becsause I didnt have a vent on hand). where can I get a properly vented gas cap?
Dan Miller
K15SG
Indiana
Daniel
K15
Edward Maxwell
Right side of WA
Edward
I bought check valve vents, built brackets and put them between the rear quarters and the inner bed side as high as I could. I had them just above the tanks on the frame when I deleted all my stuff and the first time I pumped cool gas out of the ground on a hot summer day my $4/gallon ethanol free expanded and ended up on the ground.
The link above is the ones I used.
Edward Maxwell
Right side of WA
Edward
Oh DO NOT ask butt pirate 4x what to do as those hillbillies will chastise you and tell you that you, expecting them to engineer your way out of this problem is pathetic.
That was my experience, it sucked.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
The only downside to a check valve is that it only operates in one direction. Theoretically, you’d want it to operate in both directions. To vent positive pressure accumulation and to draw air in to displace the fuel being drawn out. Probably not a huge deal in a lower fuel demand engine, though.
Edward Maxwell
Right side of WA
Edward
Per Tanks inc website these valves are open to atmosphere to relieve pressure and vacuum avoiding performance issues and potential damage to the tank until you park your vehicle upside down at which time it checks and allows the driver time to depart the vehicle safely.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Okay so you’re referring to a rollover vent like I linked to earlier on in the thread. That’s what I have.
norman baker
ellijay,ga
norman
1976,1981,1982,1984 1985
k20 ,c10 ,c10,c20, c10
none, 250 ,305, 454, 305, 454 ,
i use mine as a return line from the carb low pressure , but replace the hose it is only rated for vapor, not liquid fuel.
texasmike
Conroe Texas
When my truck is back on the road, I'm going to put my canister back on and reconnect the fuel tank vent line. Although a vented cap would probably be easier and just as good, like you, I don't know exactly what cap to buy that would fit and work properly.
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
I believe an 84 is a screw in gas cap, if so i dont think they sell a vented screw in cap. If it uses a cap with 2 ears on it you need one from a 73-74 that didn't have an evap system.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
drill a 1/16" hole in any gas cap and voila, vented cap.
MikeD
