What should my new seat be????
aGood'olBoy
Waterford Pennsylvania
Jeremiah
Alright I got a couple ideas where I wanna go with new seats in my truck. I have a broken ripped vinyl bench by the way. I understand the 89 to 91 suburban bucket seats are one of the easiest swaps. But they always come in a ridiculous "tacky" color. I want black or grey just something classy. If I did buckets I would get a jump seat console so I could still have a middle seat. Another idea I had was a bench with a fold down armrest from like a newer Tahoe. Don't remember where I saw it but it was classy and clean. A bench seat would be a easier swap anyways. Also don't limit your suggestions to just GM, I don't have an issue with putting a gasp* ford seat in my ****** Chevy. So let's hear some ideas. As always any and all input is appreciated.
rich weyand
Bloomington Indiana
Rich
I went with new, aftermarket, semi-custom 40-20-40 buckets with the fold-down console and jump seat. I did them in leather; they're cheaper in cloth. Here is my write-up from another forum.
I installed leather 40-20-40 buckets from discountvantruck.com, so here's some pics and a review. They sell a bunch of different kinds, so this only applies to the 500 Series, and only to an install in a 1978 K-10. Adjust accordingly. Also, I have no connection with this outfit, just my opinion after putting these in my truck.
Quality: The seats and frame and all are built like a tank. The leather is good quality and the sewing is superb. The seats are all leather everywhere, not leather seating surfaces and vinyl elsewhere, or in the back, or where you can't see, etc. It's all leather, period. The foam and springing appears top-notch and is very comfortable. Dimensions, features, look, etc. are all as per description and photos on the web site.
Riding position: The seating position ends up a couple inches higher and an inch or two closer to the wheel. When I put the seat back more vertical than stock (which is better for my back problems), what I saw centered in the unadjusted rear-view mirror was the inside of the tailgate. Some of that rise is the seat height and some is the seat back being more vertical. Also, the springs and foam in the new seats are new, and the old seat, while reconditioned, was probably lower than stock from sag.
Ordering and delivery: Linda was easy to work with. I wanted a brighter red than their stock colors to better match the stock interior, and she offered further samples. The stock color was more burgundy and looked brown next to the stock interior. The red sample she sent after talking it over with her is a better match. (It looks orange in the flash, but it's bright red.) Delivery was "three to four weeks"; it actually shipped four and a half weeks after order, and took a week to get here. Thanksgiving intervened, however, and they shipped 20 business days after order. The order was filled correctly, with the right colors in the right places, heaters and lumbar supports included as per order, the correct brackets, etc.
Instructions: Instructions are rudimentary but sufficient. The instructions said to mount seats, console and brackets to the frame and put the whole thing in as an assembly. That looked pretty difficult, as the whole setup is larger and bulkier than the stock seat. We put the frame in the truck, then put the brackets on and left the bolts loose, then mounted the console (take the little tray out to get at the mounting bolts), then mounted the seats, then got the floor bolts started, then tightened the brackets up. To mount the seats on the frame inside the truck, we put a small piece of 4x4 under the frame to hold the whole thing up so we could get access to the hardware underneath.
Overall value: At under $1500 delivered for this setup, it's a tremendous value compared to what else is out there.
Fitment and tweaks: If you just put everything together as they say to, it will work fine, but there are some tweaks. The brackets for the 73-87 Chevys has a weld seam on the inside of the angle that holds the frame away from the bracket about 3/16". Now, the brackets end up in the right place to bolt into the floor, but I didn't like that gap, so I put washers in to fill it so I could torque them down without distorting the frame or bracket.
The seating position is a little close to the wheel, and at the same time the seat didn't go all the way back -- it hit end-of-track. Also, the seat of the jump seat was far enough forward that the transfer case shift lever on the modded NP203 was just against the jump seat in 4HI. We drilled two new holes in each bracket 1-3/4" behind the existing holes, which moved the whole seat assembly back 1-3/4". This allowed the seat to go back all the way until it hit the rise in the floor behind the seats, and still had plenty of adjustment forward, and also gave me a 1-3/4" gap to the transfer case lever.
The headrests would only go down half way before they seized up, but each of the mounting rods individually went all the way down easily. A bit of measurement showed that the rods were 0.090" further apart than the holes. I put a couple of blocks between the rods and then cinched down across the rods right up against the headrest with a pony clamp until they were correctly spaced.
There is a latch release for the jump seat back. The release lever was pressed into the drivers seat bolster and it had a tab on it that dug pretty deep. I removed the jump seat back latch and release lever, as I won't be driving around with the jump seat open unless there is someone sitting in it.
We also added washers to the seat mounting bolts where they went through slots, and replaced the provided nuts, which have the locking teeth on the bottom, with stainless steel nylon-insert locking nuts.
So, basically, we did a bit of tweaking, which I think is well within the capabilities of most people on the forum, and there were no major gotchas, missing parts, re-machining or fabricating or anything serious like that.
On to the pics!
Stock seat:
What you get. Frame, brackets, seats, center console/jumpseat, headrests.
Test-fitting the frame and brackets:
Bracket modification. We drilled two new holes 1-3/4" behind the existing holes.
Installed, console down:
Installed, jumpseat open:
Console storage compartment:
Jump seat storage compartment (without flash, you can tell the color better):
Close up of the leather and stitching detail. The quality is very good:
cobra20
Portland, Oregon
Hans
V1500 Suburban, K5 Blazer
5.7L
can u get burb buckets down there? if u can there is a burb up near me with grey buckets I could try pulling the cushions off for you
bluex
Spartanburg SC
C15
95-99 60/40 split bench. Those have to be the most comfortable ever. Buckets from the same years are just as good...
aGood'olBoy
Jeremiah
I've called around to the local yards and noon of them have the buckets I need.:whymewhyme::whymewhyme::whymewhyme:
Those are gmt400 seats you're referring to correct? Are they an easy swap? The gmt800 looked like a huge pain in the ass.
aGood'olBoy
Jeremiah
Doesn't seem to be too hard at all from that video. I'm looking forward to hearing back from you!
bluex
Spartanburg SC
C15
Well for a crew cab it isn't as easy as that video makes it out to be. I thought the floors were similar but they are very different. Going back to the drawing board in the morning lol.
aGood'olBoy
Jeremiah
Hahaha crew cab floors are different I know that, looks to be easy for a single cab.
bluex
Spartanburg SC
C15
I smashed the drawing board today lol. I'll put one of these seats in my 78 an sell the other. I just don't see an easy way to make it work for a crew cab.
Tackelbarry
N.C.
Scott
K25 Sierra
Would the 95-99 seat in the video work in a 1979 GMC K25 standard cab? If so, that is exactly what I am looking for. Thanks in advance.
firebane
Calgary, AB
Curtis
Any seat works.. Just depends on your fab skills.
boarder421
