What rear end do I need?
circuitguy
Elk Grove, CA
BIG-C
GMC 1/2 ton Stepside
Want to change out he 10 bolt rear end in my 87 1/2 ton GMC and put in a 12 bolt complete rear end. What can I pull this from? What years? What size should be? Any info will help..
What for? The truck 12 bolt isn't as strong as the car 12 bolt, and is comparable in strength to your 8.5 10 bolt. Your stock axle is fine for most 2wd 1/2 tons used on the street... unless you got real big plans or something.
Tyger13us
BFE,Ut
Jeff
450hp/357cid
YEA bro,, truck sucks........
12 bolt gm car is 3 time's stronger..
i got a 64 chevelle/goat 12 possi that i havent blown up yet!!!!
but i havent found a truck worth puttin it in....
the one i have has been in soooooooooooo many cars... still aint blown it up yet..
i can go get some new to you pics,, layin out in the desert,, half covered in dirt,, fresh clean in side,, its had the pads cut and re welded......
my ole circle track bracket race ass end,, another timex thing i got stashed
Jeff Dodson
Angleton, TX
Jeff
I would like to find one with stock 3.73 gears and maybe limited slip
circuitguy
Elk Grove, CA
BIG-C
Thanks for the info guys. I guess it just sounds better to say "its a 12 bolt" as the car shows... :)
mick84
