What is this?
79ramp
Everett, WA
Aaron
C30
For my next potentially stupid question today: I have a '79 C30 with a 454 and it has this box which is wired into the distributor and has a 2-prong plug going to ???. I have a few questions on it:
1. What does it do?
2. Can I bypass it? Where can I find a wiring diagram for it?
3. If not, what does the 2-prong plug go to? I don't know that it was ever plugged in on my rig.
79ramp
Everett, WA
Aaron
C30
I knew it was a stupid question. Finally found a decent wiring diagram and I think this is what I am looking at. Looks like I can just connect the 3PNK-3 wire to the positive side (if you trace it all the way through, it goes to the ignition switch) and the 8WHT-121 to the tach side and cut out the rest.
I am assuming since the 8911288 plug has never been connected to anything, it has probably never done anything anyway.
CorvairGeek
Boise
C20 Scottsdale
292 L6, T400
The hood springs and cowl aren't '79 either, so it may take some sorting out.
The brake setup looks to me like something you’d see in a big block. It might have originally been a 454 truck and someone swapped in a 350.
CorvairGeek
Boise
C20 Scottsdale
292 L6, T400
Yes, hydroboost, 1 ton system. I was guessing an engine swap too, as the fan blade is so far out of the shroud, as a BBC fan shroud is too short for a little SBC.
79ramp
Everett, WA
Aaron
C30
I probably should have clarified, the picture is not my truck, just an example I found on-line. I put new valve covers on mine so the stock mounting spot is gone (plus I was not at home so couldn't go get a picture).
CorvairGeek
Boise
C20 Scottsdale
292 L6, T400
That's good! I was concerned you were in for some surprises.
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
GM lists it as an engine speed switch. I think it's related to the emissions system, but it could be part of the cruise control too.
crpntr78
Missouri
I don't believe it's cruise related. I have that same item bolted to my driver side valve cover and my truck is an 84 K2500 Sierra without any frills.
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
I ran into the same thing when I swapped in the vortec heads and valve covers. I tried finding a pic of where I put it but can't seem to find one. I don't know what it is for though.
