What is this????
87silveradok20
Ohio
Levi
Silverado k20
What are the two hoses that come out by the master cylinder used for?
75Monza
Colville, Washington
K30, K20, K20
Wow, that is quite the cluster of mods, lol. Those look like heater core hoses by size. Guessing by the hydra boost for the brakes that used to be a 6.2l diesel that someone dropped a 12v cummins in? Question would be, on passenger firewall, do you have the hoses coming out for the heater core in stock location? Almost looks like someone ran a different heater core and ran the hoses out the drivers side. Hard to tell without peaking under the dash.
87silveradok20
Ohio
Levi
Silverado k20
It was originally a 6.2 truck and there is the typical heater hoses on the other side of the dash. Ill have to take a peak under the dash to see what is in there. I haven't ever noticed anything unusual under there but then again i haven't ever really looked under there.
Vaughn
Colo Springs
Vaughn
c30
It is probably some version of a tankless water heater for engine heating.
87silveradok20
Ohio
Levi
Silverado k20
Like a block heater?
CSFJ
Block heaters are an electric element installed into the water jacket, or stuck to the side of the block.
CSFJ
What do the hoses connect to under the dash?
75Monza
K30, K20, K20
custom heated seats for wintertime since there was so little heat to go around with a diesel without blocking the grill. ;)
87silveradok20
Ohio
Levi
Silverado k20
That's what I thought but who knows what's been installed over the years
87silveradok20
Ohio
Levi
Silverado k20
I haven't gotten a chance to look yet
74propu
florida
austin
c10s/b c10 s/b c10l/b
5.3 / ?/454 tbi
that is a/c lines for dealer ad on air on the dash where the a/c vent is on the right side is there a small vent and controls for the a/c??
Vaughn
Colo Springs
Vaughn
c30
like this:
https://www.amazon.com/Kats-13150-A...&qid=1496867720&sr=1-7&keywords=block+heaters
It isn't like the block heaters that use a freeze (actually core plug) plug hole to install, it uses heater hoses to circulate warm water through the block. It says that it is a "tank heater", but that is a misnomer, it has heating elements and sometimes a pump but no tank - the block is it's "tank". It got that name because it looks like a tank.
87silveradok20
Ohio
Levi
Silverado k20
I have never heard of that. Do you have any more info and there is no a/c controls but the dash has a/c trim
74propu
florida
austin
5.3 / ?/454 tbi
yep I have one in my 1974 and my dad had one in in his 1978 that he bought new .if you look in the glove box above the heater box you should see a fan unit and a/c unit there. It is like a under dash unit but tucked up in the dash and work very very good .
87silveradok20
Ohio
Levi
Silverado k20
So without looking under the dash you wouldn't know it was installed?
crowe-t
