What cover is this?
TubeTruck
East TN
Denis
Suburban K10
LQ9
This is the flexplate cover that was on my TH350. I don't believe it's the right one because only 1 of the bolts was in, the upper opposite the starter. Seems someone drilled a hole in the bell housing for the middle bolt hole on the starter side and used a bolt and nut.
Any ideas?
Dutch Rutter
Independence, Or
Joshua
TubeTruck
East TN
Denis
Suburban K10
LQ9
That was my guess, that it came off a 700r4
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Any ideas?
If you need a th350 cover ive got one
TubeTruck
East TN
Denis
Suburban K10
LQ9
Thanks but I'm going to run it open for now. I don't wheel the truck and hopefully will be putting the 4L80e in by the end of summer.
nvrenuf
Mobile, Al.
The transmission shown in the first pic is a regular case while the aluminum converter cover is for an "HD" case. The regular cases use a stamped steel / tin cover that's held on by small sheet metal screws. An "HD" case will have bosses cast in to the flange for 3/8" dia bolts that hold the thick converter cover on.
This is an HD case -
TubeTruck
East TN
Denis
Suburban K10
LQ9
TH350 though or 700r4?
nvrenuf
Mobile, Al.
Same either way, including a 400.
As far as I know, the only difference in HD cases and covers is for the 4l80e.
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
The heavier cover was to attach the torque rods from the transmission cover to the bottom of the motor mounts. All 4x4 square body trucks with an auto trans had this.
nvrenuf
Mobile, Al.
To add.... all after around '78 / '79, none before. 80's 2wd's could also have had undrilled HD cases with the thin stamped covers.
QBuff02
Central IL
Quincy
That's a heavy duty cast cover as you've read. I thought they were th400 specific until the overdrive trans came along, and see they work on them as well as a few other applications. In a perfect world they bolt to the bellhousing and there is a set of truss rods that go from the motor mounts (there's an extra set of brackets between the engine block and the motor mounts for this assembly to work) down to the cover that bolt into the bolt holes on the center of the cover, and then another rod that goes from the right side (3 o'clockish) bellhousing bolt back to the passenger side of the transfer case. It ties everything together and is important to keep from breaking bellhousings on transmissions in high torque/stress environments. Here's a pic of the driver side setup on mine for reference.
HOTFOOT
northwest ct
michael
gmc k3500 srw
same cover on my 80 k3500
80BrownK10
Greenwood, SC
Nate
I have a thin stamped cover on my th350. It wasn't there when I got my truck. I got one from a junk yard. The guy said this is the light duty transmission that has been swapped in. I knew it was changed and just recently due to this forum found out I have a non lockup model where I should have a lockup as well. I had no idea the real differences in them though.
TubeTruck
East TN
Denis
Suburban K10
LQ9
Yup, mine had the torque rods and plates sandwiched between the motor mounts and block. I'm guessing the transmission is not original since I had the plates, rods, trans cover, but the trans cover does not bolt to the transmission.
