What’s the best way to fix this?
Gman73
Sacramento
Gary
Ck20
350 v8
So was cleaning up my fuse panel and two things went wrong. Look at this pic and tell me what you guys think. I pulled out the flasher for the hazards and lost one pin completely the other is sticking out. Also one side of one of the fuse holders broke off.
Turbo4whl
Downingtown, PA
Wayne
Jimmy
That is a typical problem on a well used work truck that has a lot of hours with the flasher on.
Cheap fix is pull the two wires from the back of the fuse panel. Add some length if you need to, then crimp or solder spade connectors on and plug in the flasher. They sell flasher plugs too.
Perfect fix is a new fuse panel and replace most of the connectors on all the wires, (labor intensive) but then it is like new. Trying to just replace the wire connectors and putting them back in the melted fuse holder will only create the same problem next time the flasher is removed.
squarelyfe
NORCAL USA
Larry
k25
As far as the flasher goes... Remove the two screws that hold the panel in, pull it forward to gain access and with one hand push the connector back in while pressing the flasher in with your other hand.
