Went from love to hate.
Kapdin
North Dakota
Lance
1977,1979,1984,1987,1988
Silverado K30, Scottsdale K20, Silverado C10, Silverado V10, Silverado V20
400ci, 350ci, 350ci, TBI 350ci, TBI 350ci
soo ive been runnin the wheels off my truck since i got it back. and when to start it today and...... no ****** spark not a single try. Its got new coil,cap,rotor,ign. mod, wires, plugs snugged up wires to the cap and dialectric greas..... wat the fug keeps happening? How can it go from running good to i had this problem so i replaced all that then ran great for a month or two and now im back to square one....very irritated right now.
GOBR
Memphis
Ignition switch? Mine was havin intermittent no spark problems but I have a toggle for the ignition. I guess it would be the same tho...... If you replaced everything else I dont see what the problem could be. Pickup maybe?
Is there power to the coil - key on?
Kapdin
North Dakota
Lance
Just got it running again. But yea i had power it, i tightend the connections to the cap. I broke it all down again. started from the bottom on up, contact cleaner and air and a little emery cloth, the only thing i can see or think is thos dog ears that must spin outward with rpm get stuck or something cus thos were the only things that felt/look some wat rough and stiff, so cleaned and even put a little dialectric greass on them as like a lub. then put it all back together and boom instant fire just like last time i had problems.... just so frustrating cus now i can't trust it go go anyware.
towjoe
Lafayette,IN
joe
78,80,81,81,86,88,89
K30's or V3500's
I'd invest in a new distributer. There only around a $100 new. I'm going to bet the pickup coil is going bad at the top of your. Plus if you put a new distributer in yours it should have new advance wieghts on the top that will help your fuel milage.
GOBR
Memphis
Yeah, those dog ears are the advance. That wouldnt cause a no spark issue tho. If everything is new besides the pickup that has to be it. Ive seen a PCM do this but it usually just goes out and aint intermittent.
towjoe
Lafayette,IN
joe
K30's or V3500's
If I read right his truck is a 79, should be just a one wire feed HEI
Kapdin
North Dakota
Lance
yea, stock 79 dizzy. But ok drove the piss out of it tonight. That has to be the problem, or atleast let me ask if the pickup coil is going out will it cause an intermitiant missfire at idel and once and awhile kill the engine for a sec or two while driving?
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
I wouldnfab up a wire that you can hook to your battery, and run power directly to where the pink power wire plugs in to your distributor, then drive it, and see if it cuts out...if it doesn't, you should look at your ignition switch. Note: the truck will not shut off with the key if you do this, you must disconnect the wire from the battery.
Did you use AC Delco parts on your ditributor tune up, or aftermarket?
GOBR
Memphis
Yes it can. I agree tho, run wire from battery straight to hot lead on dizzy. I replaced ign module and pickup on my dizzy to find out it was my ignition switch the whole time. It would miss at idle and cut out while drivin. Did it more after it warmed up.
Kapdin
North Dakota
Lance
huh, i might just go try this. i used napa eklin parts in it.
Kapdin
North Dakota
Lance
fug, just did it, same thing so cross of the ignition switch.
Jims86
Patterson,Ca
5.7 TBI
Echlin not bad, NAPA has Airtex/wells parts under their name too. If I cant get delco, I go airtex/wells in a pinch.
Kapdin
North Dakota
Lance
well, so i'v never pulled a dizzy sooo even knowing i replaced everything you still say worth getting a new one vs just a pickup coil? can you give me an overview of wat im infor? also wat dizzy should i get not break the bank but a good bang for the dollar.
Jims86
Patterson,Ca
5.7 TBI
I have had good luck with a1 cardone, they have them at Orielly for $100 + $20 for the core.
Johns C10 Hubcap
