timing issue
Ohearchai
Washington
Martin
V1500 Suburban
1990 v1500 suburban 5.7 350 tbi, Changed plugs, wires, cap and rotor, disconnected the ect, adjusted timing a touch, reconnected the ect, took it for a drive, gotta a block, starting running badly, almost misfiring, actually stalled. Got back home, turned her off, started her up again, hooked up the timing light, she was 20 degrees advanced, on a whim disconnected the ect, she went right back to 0 degrees, reconnected the ect, stayed at 0 degrees. Turned her off, started her again, back to 20 dgrees advanced. what am i doing wrong.
gmbellew
Kansas city
glen
suburban 1500
timing is set to 0 with the bypass unplugged. Do not plug in the bypass with the motor running.
If it was running fine before, I’d double check whatever you touched.
Smtty58
Mass.
Lyle
R3500 Crewcab
The ECM sets timing based on input from several sensors. First set, check all grounds. Most signals are in millivolts, a dirty ground sends an incorrect signal. Then troubleshoot sensors. I assume no codes, or you would have posted that here.
NikiFm
