Weird wheel question?
Gman73
Sacramento
Gary
Ck20
350 v8
My 73k20 has 16.5 x 6.5 inch white steel rims, 8lug I measured the bolt pattern center to center and I get 6 inches, and the center hole is 5” why can’t I find any rims for it, seems everything is 6.5 bolt pattern?
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
The lug pattern should be 8x6.5 i think the center bore is just under 5 inches
Ellie Niner
Tucson, AZ
Tory
K10 Silverado
LE9 305
All of the common 8 lug patterns I can think of are the same 8 on 6.5", which yours should be. I think the only hangup was that Mopar used a larger center hole in their wheels, which wouldn't affect you either way.
Have never run into 8 on 6".
Gman73
Sacramento
Gary
Ck20
350 v8
thanks guys I may have measured wrong so 6.5 it is And yes the center hole is right at 5 inches
Joestreml
