Weird reverse issue
ulm4lyf
Trevor
Sierra Grande 15
TH350
When the trans is cold, like sitting for several days, when I put it into reverse it doesn't always immediately go into gear. This almost never happens when the truck has been running for a while. Am I looking at a complete overhaul? Truck has very low miles ~57,000.
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
Fluid level cold is correct?
ulm4lyf
Trevor
Sierra Grande 15
sometimes. It has a speedo cable leak as well as a pan leak. Planning on fixing both of those this weekend.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
If that’s your only concern, relax.
After sitting a few days the torque converter naturally drains into the pan. Once you start the truck it takes a couple seconds to refill the converter.
Regardless of what people say, there is no reason to fear changing the fluid and filter on a high mileage transmission, assuming the trans works correctly BEFORE dropping the pan. It’s good preventative maintenance.
If it makes you feel better, drop the pan, replace the filter. This is a perfect opportunity to see how much crap is in the pan. Hopefully, there is just a little debris and crud in the pan, that’s normal clutch and bushing wear. Replace the filter, put a magnet in the pan (assuming the trans didn’t have one) reinstall the pan and refill.
Unless you have other problems, or see something really bad in the pan, I wouldn’t have it overhauled.
I'll go one further than what Matt said. R&R filter and put a drain plug in the pan( just to make life easy) drain an refill once a month. Although not perfect it will be damnbnear a complete fluid exchange.
FenderBanger
