Vent window rebuild
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
Just wrapped up rebuilding my passenger vent window. Not perfect, but I'm satisfied. Man, what a PITA!!!
A before and after shot. Maybe you can see finished one due to the glare.
Driver side to be done later.
crpntr78
Missouri
Looks great! Where'd you get your seals from?
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Nice job. Both mine are crap so I'm gonna have to do the same job.
That looks great Charlie.
I'd imagine you didn't take pics along the way did you??? This would have a been a good write up "How To" tech thread showing all the steps. If you did take pics and wouldn't mind putting a step by step Hot To together it would certainly be appreciated. You'd get your claim to fame for participation on GMSB and most likely end up as a sticky in the window/glass section for many members to see. I'm sure it would be one often found via web browser searches as in Google and such. Good Job though even if this is all you got. :waytogo:
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
Thanks guys.
Did not take pics. There is a video on youtube that did this and I watched it several times. Mostly time consuming especially when I had to paint and wait till dry. Video I watched was the one that had 9 parts. There is more than one. Really helped.
I got the parts from ebay.
Thanks guys.
True, we can find anything on Who Tube just about. We're just a bit stingy like that though. We like our own In house How To when we can get it. That way, discussions, tips, tricks, part's purchase location, price, etc can all be discussed. And things change too, we can always add update as needed and keep more up to date info as far as location of parts, price or someone here might have used even. It's all good though. At least we know there's a video out there somewhere if someone needs it.
So more members get to see it if they're looking, I've moved this one from Tech Discussion to Exterior > Glass & Mirrors section. :waytogo:
animal
Lee
c10 silverado
350ish
Awesome looking job. Well done :waytogo:
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
:signs8:
Nice job, Charlie! Mine are fairly fresh, as well. Have you thought about conditioning them to help them last longer, or do you think that’d be worth even doing? I’d hate for mine and yours to start cracking up in a few years. If anyone else has thoughts, let’s hear them!
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
Not sure about conditioning them This was my first one and although it was not too hard, seals were troublesome (time consuming) to get in frames. I still need to do driver side and will probably do it in the next couple of weeks or so. I they will last 20 years, then I'm ok with that. LOL.
The big foamypirate wrote this about 5 1/2 years ago - check it out, it really is a great tutorial. The visuals he provides are outstanding.
http://www.gmsquarebody.com/threads/vent-glass-seals-diy.5224/
The following may be a bit off-subject, but FWIW: my friend Jim at Granite State Glass gave me this heads up some time ago.
Jim says that the rubber between the vent glass and the steel frame is on the shelf (at any auto glass place). That I kind of figured.
What I didn't expect was that the rubber does not come pre-formed in that U shape. It is a flat strip (the thickness varies with the application) that only takes on that U shape when the glass is pressed into the frame. It is heated and forms a water-tight seal when pressed in. The width is oversized and any excess is trimmed after the bond sets up.
He knows that I am restoring an old truck (and shooting for a real good end result), so he offered me a word of advice:
If you are looking for a near mint condition end result on your vent windows, remove the frame from the rest of the vent widow assembly and bring it (along with the glass) to the shop before you do the final steps. In other words, don't do your final finish coating until after the glass is locked into the frame or you'll probably end up doing it over.
The reason is that, the process of jamming the glass into the frame is fairly violent. It almost always results in some scratching and chipping of the frame finish (be it paint or chrome).
MikeB
Just wrapped up rebuilding my passenger vent window. Man, what a PITA!!!
Man, you got that right. I probably spent 4 hours doing just one, not counting removal and installation! Ended up using slightly diluted dish washing soap and a couple different plastic "persuading" tools. The other vent window isn't too bad yet, so I've been putting it off for 2-3 years now.:rolleyes:
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
Finished driver side vent window today. I tried to check time closer this time. Took 2 hours to disassemble, clean, prep, paint. I let it dry overnight this time instead of waiting to dry in one day. Then, 3 hours to assemble seals in frame and re-install in door. Of course made mistake and had to remove from door, correct boo boo, re-assemble and finish door. Still quite a job.
Next project, replace chrome weatherstrip locking strip in windshield and back glass. Received parts and tool on Wednesday.
Dennis Blom
