Vavle cover bolt size?
Schlagger
New Mexico
Will
C30
Can anyone help with out with the valve cover bolt size on an '83 5.7L? I got some load spreaders in the mail and they didn't come with bolts (really??) so it will get my truck on the road a day sooner if I can find out the size. Thanks in advance.
yevgenievich
Place
Name
Year
Model
Size
Should be 1/4 -20 , 1/2 or 3/4 long.
highdesertrange
kalifornia
mike
k30
I like to put studs in. well they are not real studs but set screws. they have the same threads the whole length, with a allen drive at one end. like these,
https://www.boltdepot.com/Set_screws_Allen_Cup_point_Alloy_steel_black_oxide_finish_1_4-20.aspx
then I use serrated flange nuts like these,
https://www.boltdepot.com/Flange_nuts_serrated.aspx
this give a great mounting location for mounting wire looms and such. it also makes pulling and reinstalling the valve covers a lot easier. and it looks cool. highdesertranger
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
That's a good idea! Mine already had the 1/4-20 studs on it. But I did use the serrated flange nuts on it too.
Colin
Covington, GA
Colin
K10 Silverado
350 cu. in.
I used flange bolts from ACE hardware when I replaced valve covers.
They seem to work well.
