turn signal switch install
Ontheboulder
colville,wa
greg
gmc sierra classic v2500
Well, since all roads for non working brake lights have led me to the turn signal switch. I am thinking about trying to replace it my self. I haven't done one in nearly 35 years and that was on my old 72 chevy. pretty simple steering column back then. I hope this will work out good! Any one got any tips or tricks to make it a smooth job on this 87 gmc tilt column?? I did manage to find that I had the locking plate tool,for what reason I have no idea.so gonna borrow a buddies steering wheel puller and cross my fingers!!
If you got those two, you shouldnt need much for special tools. Although if you are "in there" i do believe there is possibly something that is a wear part or also good to get at the same time, but I am not sure what it is.
is your column loose or shaky at all? Hasnt been used to pull someone into it at all I hope?
Ontheboulder
colville,wa
greg
it has a little movement but not much. I don't think I am gonna tear into it for that. fishing the wires into and out of the column will probably be the biggest pain, I think I will lowe r the column down a bit to get better access to the switch connector under the dash.seems awfully tight for my fat hands!!
Big Chip
Michigan
Kevin
C35
I replaced the turn signal/cruise control stalk in a truck I used to own a few times. It really wasn't bad to fish the wires through the column.
Ontheboulder
colville,wa
greg
a little update, got the steering wheel and the locking plate off, found one of the springs on the old switch laying on the column housing, broken. seems to be a lot of grease, normal-not normal??? Gonna take some pictures before I go any further so I can remember how it goes back together. The horn wasn't working so I will look into that as well while the truck is in surgery!!LOL
I could be remembering wrong but there shouldnt be any grease on the upper parts of the column, loose that is. Maybe on the tilt springs (maybe..) but that seems strange to me. maybe someone forced grease into there and that caused issues
350 w/203
Tie a length of string to the connector. When you pull the harness and connector out you'll have something to pull the new one in.
John-Ryan
John-Ryan
V20
Take the time and remove the bolts that hold the column to the shaft, to loctite them and retighten. Save you from having play in the wheel.
RoryH19
Rory
R10 Silverado SWB
I just replaced mine yesterday, maybe an hour or so job.
On a 78 k10, with tilt column.
Agree with lock tighting the bolts for the tilt portion. They are e-torx, reverse torx. You will need another puller.
I can take a pic of mine if you need a reference.
Ontheboulder
colville,wa
greg
Here is where I am at this morning. Seems to be a lot of grease on the turn signal switch.
Ontheboulder
colville,wa
greg
Another update,found the problem,one wire on tur signal switch burnt. I put white paint to make it more visible
Ontheboulder
colville,wa
greg
New switch is installed! Now to put stuff back together!
Carb'ed Vortec 350
I'll be doing mine this weekend.
Johns C10 Hubcap
