Turn signal bulb replacement
StickyLifter
N/A
Screw You Homophobes
N/A
N/A
N/A
Hi Everybody,
I'm sorry if this has been discussed already. I searched but didn't find anything.
I have a 1984 Sierra with four headlights. I need to replace the left turn signal bulb. It looks like I may need to take the grill off, but I wanted to ask in case I'm missing something.
Thank you,
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
On my old 84 k10 and k5, when I replaced the headlights, I believe I recall having to remove the grill because it's got the little spring that holds it down in addition to the two beam adjustment screws.
It's a sealed beam type.
WP29P4A
Nevada
Sierra Classic V1500
Hi Everybody,
Thank you,
If you can't get your hand up behind the bumper to reach the signal light you will have to remove the grille.
WP29P4A
Nevada
The spring and the adjusters should have noting to do with replacing a headlight. Never seen a vehicle that makes you mess with adjustments to replace a bulb. Should have a trim around the edge of the bulb that attaches it to the part the has the spring and adjusters holding it in place.
StickyLifter
N/A
N/A
N/A
N/A
Okay, thank you.
Vbb199
Salisbury NC
Vince
Ah yea, you're right. I wasn't thinking about that, it's been a while since I've had a 4 head light truck
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
Wasn't the original post about replacing a turn signal bulb, not a headlight ?
I believe they are different.
Vbb199
Salisbury NC
Vince
Yea here you go op.
I got a headlight assembly from an 87 I parted out.
Remove those 4 screws if you can get to them
Vbb199
Salisbury NC
Vince
And yea, lol apparently I missed that one... sheesh
The 3x3 square lamp in the grill is the turn signal hahaha tf
Imma make my exit now
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
We all have brain farts from time to time.
As long as it all works out well in the end, all is good.
Finkaire
Finkaire
California
Loren
Silverado c10
I just installed my 4 light grill and the turn signal lights appear to be difficult to change with the grill installed. The grill has three screws on the bottom, middle screw facing up. The five remaining screws attach through the top of the radiator support. It might be possible by just removing the headlight bezels?
88V30
