turboed 454
whiplash889
saegertown pa
joseph
k20
has anyone out there installed a turbo on 454 looking for specs and pics.
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Its not really that different from any other engine. You just. need to decide what you want to do. 1st, decide what fueling system you want to use. Carb, TBI, or MPFI.
And then decide if you want a single or dual turbo setup. The hardest part is running all the pipe. You will also want to start out with a low compression engine, like 8.5:1, and depending on how much boost you use, maybe change the head bolts to studs, and possibly have the heads O ringed for turbo/blower head gaskets.
Here is something I found on a Google search that should stimulate your brain!
http://www.carcraft.com/techarticle...w_buck_454_engine_build_part_iii/viewall.html
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
Got that issue I LOVE THAT BUILD
whiplash889
saegertown pa
joseph
k20
thanks yep thinking of just using the carb set up and probably just a single for now. its going to be a hauling/street truck. more pics to come once i move back to pa that where the truck is. thanks for the help
wildcatjason
Kansas
Jason
suburban
cummins 3.9 4bt
I'd sell yeah an h1c off a 1st gen cummins. It has a rebuild kit in it but I snapped the pin wheel. They are about 80 bucks. It also needs an exhaust housing. They are about 100 used. If your interested 50 bucks or with my current housing for 150 plus ride.
whiplash889
saegertown pa
joseph
k20
thanks for the offer but already pick one up for a duramax that was totaled here at the local yard
GOBR
Memphis
Look up english racing sand truck on youtube. Its not a 454 but a 540 twin turbo.
VFL1982
