Turbo 400 shift linkage.
ajd89
Central Michigan
andrew
Crawled under the truck and it seems im missing a couple parts. Any idea where I can find the part numbers so I can search for parts 330 331?
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
The plastic bushing is common to lots of GM cars with a column shifter. Dorman sells them, you can sometimes find them in the Help section of AutoZone or Advance Auto.
Yep, looks like the plastic bushing and washer is missing. Without those, the spring will just pop through the pivot bracket like that.
That Burb you just blew the motor in, it will have the same parts.
ajd89
Central Michigan
andrew
Hey good idea. ill have to see if its any good! If not ill check the Dorman help section. Thanks for the help!
ajd89
Central Michigan
andrew
This the right one? That suburban it was in the frame not on a little bracket. It dont sit very far in the bracket on my truck when I put it in there.
Maybe shaped a little different, but it aughta do the job just fine.
sever
