TRUCK STALLS IN GEAR AS SOON AS THROTTLE IS GIVEN
COREY TREVOR
NEW ENGLAND
COREY
TRUCK STARTS & IDLES FINE , I CAN REV THE ENGINE ALL I WANT IN PARK. WHEN PUT IN TO GEAR THE TRUCK WILL NOT ROLL , & WILL STALL AS SOON AS THROTTLE IS GIVEN . ENGINE IS 94 TBI 350 SMALL BLOCK OUT OF A 94 CHEVY VAN , TRANNY IS A TH400 , TRUCK IS A 76 K20 . COULD ANY BODY HELP ? THANK YOU .
75Monza
Colville, Washington
K30, K20, K20
Had similar issue with a 90 TBI that I have, messed with a bunch of stuff till found that fuel pump didn't have enough pressure. Could be others too, but would start with a pressure test on the pump.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
9 psi at the lowest, 13 the best.
75Monza
K30, K20, K20
The list of things I went over...fuel pressure regulator, spring can fail; swapped the computer just for kicks, not it; the injectors had odd spray, so swapped another throttle body in, not it; fuel filter, not it; finally the pressure test on the pump...would flow great until you load it, then barely had 5 psi. Replaced it and worked.
60Denais
