Tranny spews fluid
Nurchburgler
San Diego
Brandon
Custom
So, my tranny dip stick spews fluid out of it onto my valve covers.
I notices that I overfilled her..and reduced the fluid..but today when she was warming up she spewed fluid again.
I drove her down the block and it didn't happen again. Wtf? Bubbles? Air gap?
I don't get it.
Thanks
Th350 tranny
350 engine
MrMarty51
Eastern Montana
Martin
with the transmission at operating temp.shifter in park,on level ground,the fluid level should NOT be above the full line.
Operating temp is not driving it a couple of blocks,operating temp is in like ten or twenty miles.
Nurchburgler
San Diego
Brandon
Custom
Sorry if I don't know what I'm doing. Thanks for the answer..I will take er out longer and check levels again.
Boone83K10
Boone, NC
Benjamin
you said you overfilled it... did you drain and refill which caused an overfill. When you drain and fill you only add like 5 quarts back.. not all 11 or whatever it is.
One other thing.. is your dipstick locking down on the tube?
TexasOutlaw87Cummins
santee
cody
k 30
5.9 cummins
Back in the 90s I was a young ! Be carfull cuz this is how my moms old truck caught on fire ! Then a few weeks later chevy sent her a new dip stick to solve this problem ...
Nurchburgler
San Diego
Brandon
Custom
I drained and refilled..I under filled, and then over filled..lol
I am so new to this **** I made a mistake of not checking at temp.
So I drained some and checked at temp (I thought).
Need to drain a little more and check again.
Also the stick does click but it may be coming loose.
Thanks
X-cabsquarebody
Western NC
Billy
C10, C10 ,K30 , 3500
305 TPI, 454, 8.1
My truck did the same thing years ago. Turned out to be a dirt dauber nest in the vent tube on top of the trans. Cleaned it out, problem solved.
towjoe
Lafayette,IN
joe
78,80,81,81,86,88,89
K30's or V3500's
Vent tube like said above biggest cause. I got one doing same thing tho that has a clear vent tube that I still haven't figured out myself
Todd Lemon
