tranny fuid leaking
Don.V
nor cal
donny
my tranny is leaking and is not from the pan. when driven it doesnt shift right. the other day i was driving and notice the wierd shift. i pulled over and had to put tranny fluid in and still feel the same. sum1 please put me on game. i hav 82' C10 Silverado with a 7oor4
It's leaking because you had to top off the fluid, or you know it's leaking because it drips on the ground?
Don.V
nor cal
donny
it drips onto the ground.
oopsman_09
Nampa, ID
Aaron
sierra classic c1500
check the weep hole on the driveshaft.
79K10
Sacramento,ca
Ryan
350/th350
i had one with the dip stick o-ring missing on a truck i bought , i replaced that and it was fine
Another common overlook, is the o ring at the TV cable where it goes into the case. The O ring gets flattened out, then will leak. Normally, this will usually leak until the fluid level gets under that point and then pretty much stop leaking. It's not under pressure at all so it just leaks enough to get under that point, then the leaking stops. But, many times that isn't low enough to make the trans not shift, so you may have another issue. Where is it leaking from? Front, rear??? Driver side or Pass side??? Could be the Servo seal, or front or rear seal also. :shrug:
Swims350
Logan WV
none
clean it all really good, brake clean, gunk, carb cleaner something, spray it and rub it down, make sure it's dry and clean of any fluid, then find your leak.
GOBR
Memphis
R10
Check the speedo gear and/or governor cover. When I worked at Coleman-Taylor Trans we never used the o-ring on the governor cover just black silicone.
sallyjeank10
