Toque Converter
ThreeLRanch
Cleburne TX
Kenneth
I have this on my 700r4 and can’t find really anything on it other then K2 makes it , does anyone have any thoughts ? New motor requires a 1600-2200 stall but I’m wondering since this might be a non stock stall that I might be ok with it Is there any way to really tell without pulling it off ?
Moderator
The stall rpm will vary with application. The listed stall range with an aftermarket converter will just give you a general range of what it could be.
It's probably fine though since it is most likely a stock converter. A 1600-2200rpm stall range is within the scope of a stock converter.
hauto85
