To replace or not replace
88Squarebdy1ton
Glenn
R30
6.0L w/ 6L80
So I have a '88 R30 (1 ton crew cab dually). Think original camper/RV tow vehicle. Came with a 454, Turbo 400 and 4:56 rear end. Could pull a house down but was slow at top end and used a LOT of gas so last year replaced engine and transmission with a 6.2L w/ 6L80 out of a 2015 Escalade. Runs great, cruises 70-80 mph easily (not towing), but still generate about 2700 +/- rpm for that speed. Someone has suggested a higher rear gear ratio, but I'm on the fence. They think I should be able to cruise at 75 w/ about 2000 rpm (and resulting better mpg).
I am not yet, but plan to pull a loaded 3 horse trailer w/living quarters or a 5th wheel RV in the future and want to make sure I'm not struggling on the low end. Any thoughts?
Pulling and good MPG don't go together. Imho, leave the gearing alone if you are going to pull.
88Squarebdy1ton
Glenn
R30
6.0L w/ 6L80
Thanks for your reply. I agree and not really concerned about the mpg so much, it's certainly better than it was. I just am not certain that running 2600-2700 rpms consistently are too much for engine life either.
blackbeard2011
