The Quest For Overdrive . . .
remove the 208 transfere, sorce a car or 2wd truck tailhousing. Use my 350 torque converter, should work.
But the output shaft itself is a different length
jjester6000
Illinois
Jack
C1500
Okay, after driving this thing 437 miles trouble free miles over this long weekend, I REALLY want an overdrive now.
And I think this is going to be my cheapest option. (They want too much for this one)
I'm not 100% sure, but I've heard that some of these R10's are the same length as my Saginaw, and some of them aren't.
Either way, I think it'll be a pretty easy swap.
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
You have 3.55 gears. A 30% drop puts it at 2.485. That 327 is just fine running at 2,600 rpms which is 70 mph maybe faster depending on your tire diameter. @Ricko1966 will tell you, not just me, but you need rpms with a flat tappet engine to oil the top end sufficiently. And $550 for that transmission isn't bad, but you'll need to rebuilt it no matter what.
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
Oh yeah, direct swap, but the outcome will not be what you expect if you install it.
duncan_schawalder
