TH400 questions
Luis of EP
El Paso
Luis
r-20
If i have a TH400 do i need a adapter of some sort to put a transfer case?
Like a np205-np208
Yes, I don't know of any transmission that doesn't need an adapter for a Tcase if it's going to be a married unit. Some manuals have the adapter built into the tailshaft, but all automatics I know of need an adapter.
john55
illinois
john
not sure if this is correct place to post mt th400 shifts great but seems like it could use another gear instead of 3 speed must be the 410)1 rearend
Yepper, 4.10 gears will give that feeling. We're not used to high rpms these days. Wasn't a big deal when speed limits were 55. Have you counted the 2 shifts and know for sure you're have 3 speeds?
john55
illinois
john
yes and double checked it also did your diff check . it will run 70 plus fine just seems like it needs to shift again kind of like the old 4 speed harley's needed another gear. finally they made a 5 speed thanks for you help
Yep, that's what it is then. Just the 4.10 gears.
