TH350 will not engage after sitting for three months
Cipriano
SW USA
Xigara
Sierra
Well, I had some time to tinker with it tonight. It needed 1 1/2 quarts but that didn't help. I can push it forward whether the truck is in neutral OR in park! That's not right.
I also engaged and unengaged the hubs that didn't make a difference. Also at the extreme left of the shifters position (park and a tiny bit more,) i get a growling from tranny area.
Thanks for any ideas
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
A shifter forks issue or if it has one, a chain problem. Something like that.
I don't know enough to be terribly specific, but gut says something dumb like this.
Moderator
Ok, so you have selectable hubs. Were they unlocked when the truck was towed from behind?
Smtty58
Mass.
Lyle
R3500 Crewcab
Selectable hubs? Did somebody try to do a part-time conversion? Consider opening the Tcase so you know what you have.
Moderator
It would be simpler to just figure out which shafts are engaged in each position.
Cipriano
SW USA
Xigara
Sierra
Alright, I got it moving! I disengaged hubs, put column shifter in neutral, transfer case in 4low and started it up. What was throwing me off was the column indicator isn't lining up properly. Neutral isn't neutral. Reverse is 3/4 of the way to reverse and reverse is neutral. Neutral begins the drive settings. I think a non-pro installed this TH350!
Turbo4whl
Downingtown, PA
Wayne
Jimmy
Simple fix now. The shift indicater needs to be adjusted. Small cable pulls it when you rotate the shift lever. The collar of shifter near the dash, there is a screw on the right side of the collar where the cable is attached. It pulls the cable to move the indicater. Loosen the screw, move it to have the pointer line up. Use neutral to line it up.
Someone should have a picture for you.
Turbo4whl
Downingtown, PA
Wayne
Jimmy
I should add, you need to take off the small bottom piece of the plastic dash to see the screw. Don't touch the little pointer with your finger. The dry plastic pointer will break off if you breathe on it.
Moderator
The linkage itself could be out of adjustment too. That's also a very simple adjustment to make, with just a single pinch bolt on the linkage rod.
If you break the pointer on accident, I "know a guy" with several NOS replacements.
425HP409
TX
Charles
C10 Short Wide
It was towed to my house, rear axle elevated, front axel on ground. Could that have done something?
that should not have caused any problem. I am leaning to fluid level.
jw23655
