TH350 Help
ceejay
OKC
CeeJay
Looking under there today and noticed alot of fluid seems to be lurking around the pan area. This plug I took a picture of seems to have alot of gunk around it along with some fluid. Is that the speedo cable? The speedo hasn't worked since I've gotten this truck, I'm thinking this could be why. Would like to figure out why it was leaking as well. Took some pictures of the seal around the oil pan. Can't really tell if it's leaking from the seal, but looks rough.
ceejay
OKC
CeeJay
Picture 3 and 5 is what I'm referring to.
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
That's your speedo cable and vacuum modulator. I'd clean all the oil off it and drive it a bit then you could get a better idea of what is leaking.
Octane
Atlanta
Eddie
Common cable connector leak.But I'd take that advice and spray it all off good.
DAT_141
