Temp sensors
Doppleganger
OH-MI: Just like it sounds
Having a blonde moment......I have a temp sensor for the new gauge but need one for the electric fans. Can I install a second one just like it or is it different?
Thx
WP29P4A
Nevada
Sierra Classic V1500
When I had the electric fans on the Charger, it used a separate sensor that connected to the relay/controller, that was adjustable for temp.
R Carnella
Long island
Rich
Suburban V2500
I used a three wire temp sensor, basically a duel output. One signal to pcm other for Gauge.
Doppleganger
I've got ports in both heads for a temp sensor....one is going to the gauge - the other would be near the relays for the fans so thought I'd put one there also.
What temp does your fans come on?
Those are handy. The earlier ones used in the 3x00 v6's were standard npt thread too.
Turbo4whl
Downingtown, PA
Wayne
Thx
No, you need a temperature sensor switch. This will run full voltage to your relay. The gauge sensor has a resistance to match the gauge. If you don't have a PCM running your engine, you need an older sensor. The PCM sends a 5 volt signal to it's temp sensor, reads what comes back. This will not power a relay. The PCM switches 12 volt power to the fan relay.
Many earlier systems had the sensor/switch in the radiator. They would be a lower temp than one used in the cylinder head.
Doppleganger
Its EFI so does have a PCM. How it operates that - dunno - haven't gotten that far yet. lol
darrel
