Frankenchevy
Proverbs 16:18
- Jan 3, 2018
- USA
- Jeremy
- Square
- CUCV
- Small
When I had my cluster out, I wiped my gauges with a terry cloth. In order to completely wipe, I manually moved the needle. Now the gauge is reading 40-50 degrees higher than it was before. It wasn’t accurate before, read 160 while 185. Now it reads 210.
Is there a position I should move the needle to begin with, or should it be able to move to the correct position the next time the key turns on?
Side question, any recommendations on aftermarket clusters that look similar to factory gauges but more accurate I.e. Autometer, etc?
