TBI not emitting any fuel (crank no start)
mr heavy-chevy
WA state
fox
i hear the fuel pump prime up, it cranks strong, it fires with starting fluid and/or gas in it, but dies once that is gone.
i don't think its spitting ANY fuel...
please help!!!!
i want this fixed TODAY. it cant be that difficult....
mr heavy-chevy
WA state
fox
i checked the injectors, theyre good.
do i NEED a "noid light" to check current or can i just use a test light or a DMM?
Georgeb
Wisconsin
George
K10 Burb Z71
You will want to use a noid light. Also check for a blown fuse for the ecm. If there is no pulse to the ecm indicating there is spark there will not be injector pulses.
mr heavy-chevy
WA state
fox
my fuse block is badly corroded, but i pulled - checked - reinserted, and voltage checked each fuse....
so im pretty certain its not a ECU/ECM issue since the big voltage is getting from the battery to the junction block OK. it drove fine last week.
i will check voltage TO the injectors with a light as soon as someone can come help me..... if that is good then its probably the fuel pump taking a dump.... ill do the fuel filter, but, i think its gonna be the pump...
it backfired, and caught on fire. backfiring is a sign of low fuel pressure (says the internet)
Georgeb
Wisconsin
George
K10 Burb Z71
You could rule the pump circuit out by feeding power to the pump prime terminal by the pump relay. A common issue is damage to the wires for the injectors as well.
mr heavy-chevy
WA state
fox
the noid light test failed... no light/voltage for either injectors.
so now idk what to do
Georgeb
Wisconsin
George
K10 Burb Z71
mr heavy-chevy
WA state
fox
FIXED IT!
the injectors got voltage with the ignition ON so i gobbed conductive grease into the TPS and the ignition control module connectors... fixed.
i guess it was just a loose connection =)
Georgeb
Wisconsin
George
K10 Burb Z71
I figured the ecm wasnt seeing the pulse from the ignition module and thus not firing the injectors.
mpatton
