Taillight housing
thaddybob
MN
Thad
Any ideas on how to get the bottom screws out on the taillight housings that have been mutilated by the po? There isnt even heads left on them.
Thanx much fellas.
8T6K5
AZ
L98 350 TPI
No heads? Is the housing still on? Can you score them and use flathead? Otherwise carefully drill them out...
Factory are stainless Torx heads aren't they? Maybe an easy out might grab in there? :shrug:
MrMarty51
Eastern Montana
Martin
Probably not screwed up by PO but rather the heads are rusted off.
Originally those were phillips heads screws.
I hace used various tools and chipped/chisesled away until the head was completelu gone,then,pulled the tail light off of what was lefdt of the screws shank,got a hold of the shank with a vicegrip and unscrewed them.
Worked for me on several that I have picked out of the scrap yards.
thaddybob
MN
Thad
Thats what i started to try to do was chip the last of what was left of the heads but didnt want to make a mess of it if it broke. The top 2 hold it in just fine but have a set of new housings and lenes from a buddy that I was going to put in. There isnt enough left of the heads to try much.
MrMarty51
Eastern Montana
Martin
Chip away.they will slide right oft if enouhg of the heads is gone,if You got different ones and just trying to salvager the old,well,sometimes a mans gotta do what a mans gotta do an that would be to break the old houseing then remove the screw from the clipenheimer.
Driver4r
Nebraska
Trevor
k10,c20
87 Would have been Torx.
Im not exactly sue when they started to convert to them tho. 1979?
Stroked
Beloit, Kansas
Jared
My 84 has torx head screws
Sent from my iPhone 4s using Tapatalk
The same size Torx bit fits the headlight adjusters too. :)
MrMarty51
Eastern Montana
Martin
I have taken some apart that had torx on the lens covers for screws but they had phillips holding the backing to the body,thems the rusting out ones.
Stroked
Beloit, Kansas
Jared
Ohh yea...now that you mention it, the ones holding the housing to the bed were in fact phillips head screws. The lens to housing screws were the torx. I just had one apart last Sunday, you'd think I could remember that. Lol.
Driver4r
Nebraska
Trevor
k10,c20
Ahhhh, i see. I thought we were talking about lens's.
attachment.php
attachment.php
:lol::popcorn:
:mexsmoke:
imyourhuckberry
